Max 4 was designed to be compatible with Win98 and NT 4. Win XP 64 is
almost nine years ahead of that. I very much doubt that you can make the
max 4 work on this OS, unless there's some special compatibility mode you
can set up. The error [xx.1.29] refers specifically to the licensing
drivers, which are tied to the OS.
If you can reinstall it with a network license instead of the standalone,
you might have better luck -- but still, max has many close ties to the OS.
Some people are having problems with max 7 on Win64, much less three major
revisions prior...
You can try the demo version of max 7 here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5659513
Max 8 has been announced, and it doesn't even explicitly support Win64.
--Cy--
wrote in message news:4926822@discussion.autodesk.com...
I am installing 3DS Max ver 4 on a new system running Win XP 64. On startup,
3DS reports
"A license error has occurred. Please restart your system to initialize the
license management system. If this problem continues, contact your system
administrator or authorized dealer.
Error [7.1.29]"
and then a second message -
"The software license failed to initialize, [Error 7]"
I tried to installed the License Manager RTS Update and got the following
error -
"The image file C:\ . . . .\My Downloads\RTC\CdSetup.exe is valid, but is
for a machine type other than the current machine."
The machine is a Dell Precision 670, Dual 3 gig processors, 2 gig ram, 60 gb
SATO h/d, Quadro FX 3400 w/256 Mb, all running on Win XP 64.
Can anybody help me?
