Installation & Licensing
Wil a Stand Alone license activate both 32 and 64 bit versions of 3d Studio Max?
1 REPLY 1
207 Views, 1 Reply
I need the 32 bit VRML importer but the 64 bit memory size.  Can I buy one 3D Studio Max 2013 stand-alone license and use it to run both versions (on the same machine, not at the same time)?
Thank you
Eben Gay
1 REPLY 1
TravisNave
That is correct.  Activation is not CPU platform dependent.
Autodesk Forums:
Administrator Productivity
