Going through the debug file on the license and can see which application a license has been taken (out&in) but what application is the feature 86829pdcoll_t_f (PD Collection Package Term) since that is a collection? I can see the Inventor(87537invprosa_2022_0f) that is a part of the PD Collection Package Term.
The same thing is with the collection 86815aeccol_t_f (AEC Collection Package)?
Solved by JTBWorld. Go to Solution.
i don't believe the license file breaks down each product in the collection
but to check run your license file through this: https://www.autodesk.com/support/download-install/admins/network-licenses/about-licensing-options-an...
DarrenP
are you running into this issue: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cascading-does-not...
DarrenP
Due to cascading you might not be able to tell what application is using a feature. There are options available. Feel free to contact me.
