Has any solution been found to Autocad LT running/launching multiple instances of webview2 for no apparent reason? I've run across it on the forums, but nobody seems to have a permanent answer as webview2 is embedded into windows, so uninstalling it is a non starter.
It freezes up my Autodesk programs on a regular basis where it will have 6+ instances running. When things are running smooth, there will be zero running and after time, it starts to lag and run more and more instances.
I've tried a support ticket and general searches where the qeustions is asked, but all I get is a circular "submit a support ticket" then they link to an article or this forum that asked the original questions without an answer.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-run-Auto...
https://forums.autodesk.com/t5/installation-licensing/prevent-loading-microsoft-edge-webview2/td-p/1...
