Solved by natasha.l. Go to Solution.
Hello @autoap96,
You can try to Reset and Change Your Autodesk Account Password to see if that will provide you with a new email notification or try to sign in afterward.
Let us know how it goes if that does not work, I can provide you with the next steps.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @autoap96,
If the above suggestion did't work for you, contact Account Management support to look into why you can not access your account.
Thank you for posting to the community, please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Helpful Links:
