I am getting this error
2015-11-04 11:22:24,217 root.LicenseEngine (cameo) exited with status 1.
2015-11-04 11:22:25,217 root.Vendor (cameo) stopped.
2015-11-04 11:22:25,220 root.LicenseEngine (cameo) exited with status 1.
2015-11-04 11:22:26,220 root.Vendor (cameo) stopped.
2015-11-04 11:22:26,221 root.Vendor (cameo)maximum number of start retry is reached.
2015-11-04 11:22:26,221 root.LicenseEngine (cameo) exited with status 1.
Any idea what would cause this?
Firewall blockage. Incorrect license manager, bad license file. Did you move the license file? If so, that would be a problem.
I would redownload the licnese manager and retry. Delete the old files and make sure you are using the new ones.
Make sure to get the correct IPV4 or IPV6 version. You want it to match the one you are set to use.
-Thank you
