Using Autodesk ID
Using Autodesk ID
Using Autodesk ID
Hello fellow Autodesk travellers
Maybe a silly question : can I use my autodesk created ID ( the one you use when posting a message on the forum for example ) on another license?
I have on my home PC a student version of AutoCad which logs in automatically with my ID , can I also log in (as in my case "Laurens Linthout" ) on the license the company I work for uses? Or should I create a new ID only to be used in the company environment?
I added a screenshot
Afbeelding1.pngThank you for your time !
DarrenP
i would keep them separate
create a new one for your student license
DarrenP
Thank you Darren for your help
