Updating Server
Updating Server
Updating Server
OK, so I am finally able to run some much needed updates on our CAD server.
But....it is not connected to the Internet and thus I attempted to copy and move the update install file to a location (network drive or thumb drive) the server can access.
Problem is I get this error:
Ideas?
I think I found a "loophole"
I can download the .exe to my local "downloads" folder, then immediately move the .exe to the network location or thumb drive, etc. and all's fine.
I hope.
DarrenP
Can you move the update directly to the server?
DarrenP
Yes, that is possible as well.
I just wasn't able to test as my current credentials to the server are not valid, so had to have a co-admin test such.
Got the Server updated overnight, but the Fileserver update failed. Trying to get that squared away and find out the cause.
OK, so I know the Vault Server and FileServer are supposed to be at the same service pack level, but since the FileServer SP failed, what errors, if any should I expect to see until I'm able to get such updated during off hours?
