Installation & Licensing
cancelar
Mostrando los resultados de
Quiere decir:
Responder
Mensaje 1 de 5
1953 Vistas, 4 Respuestas
Update Errors
I am 3rd party support for a machine shop that uses Autodesk Products.  They are running Win10, AutoCad and Inventor Pro.  We are trying to update both products through the Desktop App as well as downloading and running the executable for 2022.01.  The installer runs through to 100% and then fails.  This is the contents of the AutoCad installer file log.  No method seems to work.  I have already uninstalled all products and reinstalled the 2022 versions of these products and it still is happening.  The products do open, we simply can't apply the latest update.  Any ideas?
Thanks in advance for any direction or help.
LogFile *~*~**~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*
******* Product: {28B89EEF-5101-0000-0102-CF3F3A09B77D}
******* Action:
******* CommandLine: **********
MSI (s) (EC:14) [10:36:13:764]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (EC:14) [10:36:13:765]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (EC:14) [10:36:13:773]: SRSetRestorePoint skipped for this transaction.
MSI (s) (EC:14) [10:36:13:775]: End dialog not enabled
MSI (s) (EC:14) [10:36:13:775]: Original package ==> C:\WINDOWS\Installer\13e17.msi
MSI (s) (EC:14) [10:36:13:775]: Package we're running from ==> C:\WINDOWS\Installer\13e17.msi
MSI (s) (EC:14) [10:36:13:783]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (EC:14) [10:36:13:783]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (EC:14) [10:36:13:783]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (EC:14) [10:36:13:783]: APPCOMPAT: looking for appcompat database entry with ProductCode '{28B89EEF-5101-0000-0102-CF3F3A09B77D}'.
MSI (s) (EC:14) [10:36:13:783]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (EC:14) [10:36:13:798]: Machine policy value 'DisablePatchUninstall' is 0
MSI (s) (EC:14) [10:36:13:798]: Product: AutoCAD 2022 - Update '{743FBC5F-C8A5-4831-8F0E-D02F0A8D685E}' could not be removed. Error code 1647. Additional information is available in the log file C:\Users\ROCKY\AppData\Local\Temp\AutoCAD_2022.0.1_Update_core_2022_{28B89EEF-5101-0000-0102-CF3F3A09B77D}_install.log.
MSI (s) (EC:14) [10:36:13:798]: Windows Installer removed an update. Product Name: AutoCAD 2022. Product Version: 24.1.51.0. Product Language: 1033. Manufacturer: Autodesk. Update Name: {743FBC5F-C8A5-4831-8F0E-D02F0A8D685E}. Removal success or error status: 1647.
MSI (s) (EC:14) [10:36:13:799]: Note: 1: 1708
MSI (s) (EC:14) [10:36:13:799]: Product: AutoCAD 2022 -- Installation failed.
MSI (s) (EC:14) [10:36:13:799]: Windows Installer installed the product. Product Name: AutoCAD 2022. Product Version: 24.1.51.0. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1647.
MSI (s) (EC:14) [10:36:13:802]: MainEngineThread is returning 1647
MSI (s) (EC:CC) [10:36:13:802]: No System Restore sequence number for this installation.
The update is not applied to this product.
MSI (s) (EC:CC) [10:36:13:803]: User policy value 'DisableRollback' is 0
MSI (s) (EC:CC) [10:36:13:803]: Machine policy value 'DisableRollback' is 0
MSI (s) (EC:CC) [10:36:13:803]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (EC:CC) [10:36:13:803]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (EC:CC) [10:36:13:804]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (BC:88) [10:36:13:804]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (BC:88) [10:36:13:805]: MainEngineThread is returning 1647
=== Verbose logging stopped: 6/26/2021 10:36:13 ===
Etiquetas (1)
Etiquetas (2)
4 RESPUESTAS 4
Mensaje 2 de 5
rushabhthakkar_910
en respuesta a: Anonymous
Try Autodesk Clean Uninstall Tool..
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Mensaje 3 de 5
I've tried those solutions.  I went ahead and tried those steps again.  Same result.  Product installs fine but cannot install the updates.  Here is the full install log file for the AutoCad 2022.01 update.  Pretty much the same info as in the Inventor update install file.  I am intrigued by the line that says "The update is not applied to this product."
=== Verbose logging started: 6/28/2021 16:43:08 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Program Files\Autodesk\AdODIS\V1\Setup\install_manager.exe ===
MSI (c) (00:8C) [16:43:08:533]: Resetting cached policy values
MSI (c) (00:8C) [16:43:08:533]: Machine policy value 'Debug' is 0
MSI (c) (00:8C) [16:43:08:533]: ******* RunEngine:
******* Product: {7F4DD591-2664-0001-0000-7107D70F3DB4}
******* Action:
MSI (c) (00:8C) [16:43:08:533]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (00:8C) [16:43:08:533]: Grabbed execution mutex.
MSI (c) (00:8C) [16:43:08:540]: Cloaking enabled.
MSI (c) (00:8C) [16:43:08:540]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (00:8C) [16:43:08:540]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (C4:44) [16:43:08:543]: Running installation inside multi-package transaction {7F4DD591-2664-0001-0000-7107D70F3DB4}
MSI (s) (C4:44) [16:43:08:543]: Grabbed execution mutex.
MSI (s) (C4:E4) [16:43:08:544]: Resetting cached policy values
MSI (s) (C4:E4) [16:43:08:544]: Machine policy value 'Debug' is 0
MSI (s) (C4:E4) [16:43:08:544]: ******* RunEngine:
******* Action:
MSI (s) (C4:E4) [16:43:08:544]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (C4:E4) [16:43:08:545]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (C4:E4) [16:43:08:551]: SRSetRestorePoint skipped for this transaction.
MSI (s) (C4:E4) [16:43:08:552]: End dialog not enabled
MSI (s) (C4:E4) [16:43:08:552]: Original package ==> C:\WINDOWS\Installer\2a4f55.msi
MSI (s) (C4:E4) [16:43:08:552]: Package we're running from ==> C:\WINDOWS\Installer\2a4f55.msi
MSI (s) (C4:E4) [16:43:08:558]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (C4:E4) [16:43:08:558]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (C4:E4) [16:43:08:558]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (C4:E4) [16:43:08:558]: APPCOMPAT: looking for appcompat database entry with ProductCode '{7F4DD591-2664-0001-0000-7107D70F3DB4}'.
MSI (s) (C4:E4) [16:43:08:558]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (C4:E4) [16:43:08:573]: Machine policy value 'DisablePatchUninstall' is 0
MSI (s) (C4:E4) [16:43:08:574]: Product: Autodesk Inventor 2022 - Update '{8E019EF5-B62D-4E47-8F70-B85BAE0467BA}' could not be removed. Error code 1647. Additional information is available in the log file C:\Users\ROCKY\AppData\Local\Temp\Inventor.2022.0.1_2022_{7F4DD591-2664-0001-0000-7107D70F3DB4}_install.log.
MSI (s) (C4:E4) [16:43:08:574]: Windows Installer removed an update. Product Name: Autodesk Inventor 2022. Product Version: 26.0.15300.0000. Product Language: 1033. Manufacturer: Autodesk. Update Name: {8E019EF5-B62D-4E47-8F70-B85BAE0467BA}. Removal success or error status: 1647.
MSI (s) (C4:E4) [16:43:08:575]: Note: 1: 1708
MSI (s) (C4:E4) [16:43:08:575]: Product: Autodesk Inventor 2022 -- Installation failed.
MSI (s) (C4:E4) [16:43:08:575]: Windows Installer installed the product. Product Name: Autodesk Inventor 2022. Product Version: 26.0.15300.0000. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1647.
MSI (s) (C4:E4) [16:43:08:577]: MainEngineThread is returning 1647
MSI (s) (C4:44) [16:43:08:577]: No System Restore sequence number for this installation.
MSI (s) (C4:44) [16:43:08:578]: User policy value 'DisableRollback' is 0
MSI (s) (C4:44) [16:43:08:578]: Machine policy value 'DisableRollback' is 0
MSI (s) (C4:44) [16:43:08:578]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (C4:44) [16:43:08:578]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (C4:44) [16:43:08:579]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (00:8C) [16:43:08:579]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (00:8C) [16:43:08:580]: MainEngineThread is returning 1647
=== Verbose logging stopped: 6/28/2021 16:43:08 ===
Mensaje 4 de 5
And now, have once again ripped everything AutoDesk from this PC (this is the 4th time).  I can AutoCAD 2022 installed as well as Inventor Pro 2022 installed (with latest updates).   Inventor opens just fine.  AutoCAD gives me the error:
The License manager is not functioning or is improperly installed.  AutoCAD will shut down now
Have done all troubleshooting with regards to that error that I can find. Uninstalled the License manager, reinstalled the license manager, etc.  Same result.  Checked to see that License Manager responds on loopback IP and port - good. Turned off A/V - done.  Installed under a different account that's an Admin account on PC as well-tried that.  Always this same result.  There are other production suite software products on this PC and I'd rather not wipe and start over as that could be incredibly expensive and time-consuming for this client as well as result in possible downtime for their shop.  Any other suggestions?
Mensaje 5 de 5
Another item to check is the "User" assigned AutoCAD by the "Administrator". Have the person that is the "Administrator" on the account check their account at manange.autodesk.com to see if that particular user has been assigned AutoCAD and not just Inventor.
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
