Announcements
unhandled exception c0000005(access violation reading 0x0060b)at address 4651af5
clairelim456
clairelim456
I just opened my autocad as usual it comes out several error message and asked me to reinstall the software, i tried to ignore them and do dwg, but just right I tried to save it and flash close down and came out automated autodesk community error feedback. How should I solve it? Anyone has idea ;(
1122
Mark.Lancaster
@clairelim456
This could point to the following
If this fatal error is based on the startup of a 2018 product line, make sure you have this >>licensing hot fix<< installed
1.  You need to >>clean out<< your personal temp (%temp) folder with in Windows.  You will not be able to delete everything but try to delete as many files and folders as possible.
2.  Run a repair on your Autodesk product.  Go to Windows Control Panel/Program and Features/Add & Remove Programs, locate your Autodesk product and right mouse select to uninstall/change.  Select repair when the menu comes up.
3.  You have an outdated graphics card driver or a card that's not supported.  Don't rely on Windows telling you its up-to-date.  Go directly to Windows Device Manager and locate your graphics card under dispay adapter.  Right mouse click on the card and select proprieties.  Go to the "Driver" tab and look at the driver date.
4.  Issues with Microsoft C++  --> https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
5.  Issues with Microsoft Netframe https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
In end try each one before moving onto the next one.
Mark Lancaster
clairelim456
what does that mean ?
it came out when I try to install   Autodesk License Service (x64) - 5.1.5 Hotfix .
Mark.Lancaster
@clairelim456
Did you read my posting? If you're using 2018, make sure to install it.   However your images show you're using the 2020 product and most likely you already have it installed.
Mark Lancaster
mdavis22569
To add to what Mark posted
Have you seen the following AKN article about this:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Except...
Mike Davis
clairelim456
it happens to be the region settings. I uncheck the beta unicode option and the error doesn't appear again when launching.
mdavis22569
Awesome glad I could help
Mike
Mike Davis
