Trouble Activating Maya 2020 Student Software on Mac OS
ebujnoch
Message 1 of 10
ebujnoch
Hi!
I just downloaded Maya 2020 a few days ago and I haven't been able to activate my student license software after I downloaded it onto my Mac Laptop. Originally, I was prompted to click on single or multiple users but now I am only given the multi-user or enter serial number option. I did not receive a serial number when I requested the program and I am only a single user on a student license.
Any help will be greatly appreciated!
Replies (9)
Message 2 of 10
natasha.l
Hello @ebujnoch
It is recommended that you install the latest ALS update before installing the application. You can try to install it after the fact & see Autodesk Licensing Service Update & Single Sign On Component (2020 & up). Then restart the computer and test the product. If the issue persists continue on to option 2 (Windows) or (Mac).
If it doesn't seem to correct the issue then uninstall the application & reinstall it again.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 10
ebujnoch
Hi Natasha!
I did both the Autodesk Licensing Service Update and the Option 2 Mac choice you listed and restarted the computer both times after each download. I didn't do Single Sign On Component because it appears that is only available to Windows machines. The only change I am seeing is that the interface is different from the pop up I received earlier today when I try to open up Maya. I attached an image of what I am currently seeing below.
I also uninstalled Maya 2020 (dragged all 2020 related folders into the trash) and re-downloaded Maya 2020 and I am still having the same issue where it is asking me if I am a multi-user or to enter in a serial number.
Message 4 of 10
Message 5 of 10
natasha.l
Hello @ebujnoch
Sorry to hear you are still having issues, but there is an AdSSO update for Mac, please follow the steps again.
I have copied them below:
Update the Autodesk Single Sign On Component
  1. To download and update the Autodesk Single Sign On Component, follow the steps highlighted here: Autodesk Single Sign On Component (AdSSO) Update for 2020/2021 MAC OS product versions.
  2. Then reboot the system & test the application.. If the above steps did not help, see below for more advanced workarounds:
Reinstall the Autodesk Desktop Licensing Service
  1. In the Finder, click Go > Go to folder... and type /Library/Application Support/Autodesk and then click Go.
User-added image
  1. Rename the folders AdskLicensing and AdskLicensingService to AdskLicensing.old and AdskLicensingService.old.
  2. Open the Terminal from Finder > Go > Utilities > Terminal.
  3. Type or copy-paste the following command:
    sudo chmod -R 777 /Library/Application Support/Autodesk
Note: The Terminal will ask for your account password. Typing will show no characters. This is normal. Type the password and press Enter/Return.
  1. Uninstall the Autodesk software. For example: AutoCAD for Mac 2020 has /Applications/Autodesk/AutoCAD 2020/Remove AutoCAD 2020.
User-added image
  1. Reinstall AdskLicensing with the latest licensing update, following these steps:
    1. Close all Autodesk applications.
    2. Download Autodesk Licensing Service 10.1.1.66 installer.
    3. Decompress the downloaded file by double-clicking on the downloaded compressed .tar.gz file.
    4. After extraction, the following four files will be there:
      • AdskLicensing-10.1.1.66-mac-installer.pkg
      • adlmflexnetserverIPV6.pkg
    5. Double-click each of these and follow instructions to install.
  2. Install the Autodesk software again.
Message 6 of 10
ebujnoch
Hi Pola_S,
Thanks for your response! However, I am having trouble following all of the steps listed in that link since most solutions are for Windows but I have tried using different internet sources (wifi and mobile network). I also don't have the wire fall enable at the moment so that shouldn't be causing an issue. Really having a tough time trying to download this new version of Maya (have downloaded 2016 and 2018 this Mac already in the past). I am teaching a Maya course so I really need help as soon as possible.
Message 7 of 10
ebujnoch
Hi Natasha,
Thanks for your reply. I tried the first option (Autodesk Single Sign On Component (AdSSO) Update for 2020/2021 MAC OS product versions.) which I believe I have done before a couple days ago and the single user version still didn't show up when I opened Maya. Shut down my computer and everything before opening the program.
I also tried the more advanced option for Macs (Reinstall the Autodesk Desktop Licensing Service) but once I got to the point where I copy and pasted the command in the terminal I was getting an error saying that the file or directory did not exist (path path should be correct when comparing to my own network file path). I tried skipping ahead to Step 5 but I couldn't find a Remove Maya 2020 file/option anywhere. I did try to use this (Autodesk Licensing Service 10.1.1.66 installer.) but only one of the packages would install on my computer.
Message 8 of 10
natasha.l
Hello @ebujnoch
You mentioned a The Note  included under step #4 mentions having to provide your password, for permissions access. Where you asked for a password, what does the Terminal respond with? Or just try again it may just be a typo running the Mac chmod tool.
@ebujnoch wrote:
"I copy and pasted the command in the terminal I was getting an error saying that the file or directory did not exist (path path should be correct when comparing to my own network file path)."
Message 9 of 10
ebujnoch
Hi Natasha,
I did some digging and the link in one of your replies for a Mac Single Sign On Component was for windows. After a little bit of searching I found this update:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/simplecontent/content/au...
and then updated my Mac to High Sierra 10.13.6 and then that seemed to work! Once I restarted my computer I had the Autodesk Sign In option and was able to log in using my account to activate it.
Thanks!
Message 10 of 10
dcm357
Community Visitor
Community Visitor
Lady, your instructions don't make any sense. He's asking for help for Maya 2020 on a Apple Mac & you keep send him Windows PC instructions to a completely different software. Your advice is non sensical.
