I've attempted twice, two different links, to download and use the trial version of LT. I've been told to try downloading again, but this is very expensive for my data. I've asked the question, should I need a serial number and license for a trial version or not, but haven't got an answer from Autodesk.
Can anyone here, PLEASE, give me a straight answer on this? Do I need a license and serial number to trial the software? If so, do you know where to find it? If not, what should I do when it asks for it? THANK YOU!!!!!!!!!!!!!!!!!
Solved by natasha.l. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
Solved by megh2010. Go to Solution.
Solved by markcalloway. Go to Solution.
Solved by Darin.Green. Go to Solution.
To answer your question, you do not need a serial number to use the Trial. Once the software is installed, and during the initial launch of the application you'll need to choose Login then enter your username and password to start the 30 day trial license.
The download issue is caused by the method you're using to download/install the application (InstallNow) Instead follow the instructions below.
Downloading Solution:
Download the software from the Autodesk Virtual Agent
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Hi @megh2010
You shouldnt need to download it again.
Please can you attach a screenshot of the screen you are getting, if it is asking you to sign in please sign in to start your 30 days trial.
If you have already started the trial previously your 30 days may have ran out but you would get a error telling you your trial has expired if this was the case.
Hope this helps and if you do still have issues please attach screenshots of any messages or errors you get and please let us know if you get it working.
Mark
Hello @megh2010,
Sorry for the inconvenience. You can download your trial software via the Autodesk Virtual Agent as @Darin.Green mentioned. This article will go over some tips on how to Prepare your System before hand.
You can then select the option to "Run" on the "Product License Activation" screen, to use the Trial.
You do not need a Serial Number or Product Key.
Please keep us posted on the progress.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi Darin.Green, Thank you for your reply. I followed those steps originally to do the download. I was logged in when I did the download and I've tried the download twice so I don't see how I could be missing anything. When I try to run the software, I get a popup that asks for either the 'serial number' or 'network license' and there are no other options.
I did see mention in another post about downloading an "installer". I would have thought this gets downloaded at the same time if needed.
I'd be willing to remove it and try again, but each download cost me for data so I'm just not confident that there is something different to do yet.
Thanks again.
Thank you all for your replies. It appears I've followed those steps to do the download and install. I'm not sure how to put a screenshot in my post, but I'll work on it.
Ok, I reloaded the software from this link (from a local retailer)
https://knowledge.autodesk.com/customer-service/download-install/install-software/free-trial-install... and when I went to run, I got a third option this time, "sign in" (plus the previous 'serial number', or 'license'). So I signed in and then it asked if I wanted a 'trial version' and I clicked on that. So far much better than the last two times. But then it asked for my credit card info. So, I paid and now I have the software running. I would have preferred to have a trial period to get it set up while I still had my other autocad software, but now I just need to cancel the old license so that I don't pay for two items for too long. thanks again for all the support.
Hello @megh2010,
Sorry about that, you can also select to run as a trial by selecting it down below on the LGS screen.
I understand you paid for the product and would like to prevent it from charging you further. Please visit your Autodesk Account and run through these steps:
To access your subscription renewal settings:
Please let us know if you resolved this issue. Thank you.
Natasha
Helpful Links:
Hello @megh2010,
I wanted to check-in with you, I hope you were able to resolve the issue.
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Thank you.
Natasha
Helpful Links:
Hi Natasha,
I've resolved it per my last post.
I'd love to help the autodesk community by sharing this information, but I have no idea where the 'accept as solution' button is that you mentioned. I'm not an autocad person, I'm a business person, and I only deal with autocad (and other computer) issues as needed. This issues has consumed two weeks and I'm very much behind on my work as of today. I do appreciate the time for all your help, but instructions need to be specific so that I can follow them. If I have some extra time later, I'll try to find that button. Thank you!!
You need to come back to the posting to see the button.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @megh2010,
Sorry for the frustration. Thank you for returning to the community and contributing to help other visitors with a similar issue.
Have a great day.
Natasha
Helpful Links:
