Tinkercad Import
Not sure if this forum supports question for Tinkercad or not but I'm having some issues when trying to import SVG files.
I've tried importing the file in two versions one being an outline of the shape and the other is solid. In both cases Tinkercad properly displays a preview of the SVG file on the Import screen, but once it's imported it's all messed up.
The outline version is way more messed up then the solid version yet each resemble the actual shape of the part I'm trying to import.
The solid version is very close except it has voids where it should be solid and it has extraneous pieces / blocks tacked onto the outside edges of the curved surfaces and one large square block on an inside edge. Not sure what going on or how to fix it.
Thanks.
