Hi everyone,
I have to install Autocad 2015 in a company, but they want to do it in a terminal server. Is possible it?
1. How does I do the licencing's process?
2. What do requeriments I need for that?
3. This software would be installed in some windows server version.
Really i would appreciate your help.
Solved by ukdxb012. Go to Solution.
Are you referring to a possible Implemetation of Citrix? http://images.autodesk.com/adsk/files/Citrix_Ready_FAQ0.pdf
Thanks for asking,
I worked to company where they had a server with windows 2003 and the users worked to opening terminal server windows. I though to do the same way. Is possible o is necessary install with citrix now?
Looks like you have to purchase a specific license... knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Licensing-and-license-file-format-for-Autodesk-products-on-Citrix-XenApp.html
I know a good company in the UK called IMSCAD... http://www.imscadglobal.com/
Might be worth contacting them about your needs.
