Solved by Mark.Lancaster. Go to Solution.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
There's nothing attached so I have no clue what you are talking about. If you used the Autodesk Virtual Agent method before and you have a C:\Autodesk folder with the extract information than no you don't need to download it and you can simply run the setup.exe located in the extracted AutoCAD folder. If you originally didn't use the Autodesk Virtual Agent before to install your software, then don't waste anymore time and just follow those steps.
Mark Lancaster
Once again. No image..
If you are using your personal email to reply back to this forumn.. Don't... Return to the forum/posting, post your reply and use the photo icon to attach images..
Mark Lancaster
If that's the message you are receiving then I know for sure you never used the Autodesk Virtual Agent in the first place.. Because the method you used is called install now and it never puts the actual installation files on your machine.. So when you try to run setup.exe its looking for the install to happen again over the internet..
The Virtual Agent actual downloads the complete installation media to you and never relies on the internet again to perform the install.. Take my advice follow the steps and download the necessary compressed files and go through each step I listed. You will realize when you click on the link I provided to the Virtual Agent.. You never went there in the first place..
Mark Lancaster
