System Error Repair - License Error
Message 1 of 8
I really need to be able to draw something for a customer and I keep getting a System Error Repair Message!
License Manager is not functioning or is not installed properly. AutoCad LT will shut down now.
Replies (7)
Message 2 of 8
I am getting the same error message tonight.
Message 3 of 8
tbjdesign
I'm getting the same thing...the once a month I have to work all night, and this happens! I've too not seen this before.
I've gone through all of the steps (I can find) to reset...nothing. I use 2019 but have both 2018 and 2019...same issue.
Message 4 of 8
tbjdesign
Must have been an issue with Autodesk sign in server...after fumbling with trying their steps to repair (to no avail)...I just tried to open...AND IT WORKS!
Good luck!
Message 5 of 8
I re-booted my PC and all is well. Good Luck!
Message 6 of 8
I opened up a chat and they sent me to the Forum and a link for different things to try. Frustrating as all get out when I need to be working on drawings!
At any rate I rebooted my PC and then clicked the AutoCad LT and it loaded as it should. Who know what the issue was?
Message 7 of 8
Just to give a heads up. I had a license error & with no help from Autodesk, I found there was an update that I downloaded & installed. Now my autocad works.
Message 8 of 8
antoniosgrift
Reset License
Reset the local license information: How to change or reset a license for Autodesk software.
Update your Autodesk Software
Install all the latest updates for your Autodesk Software. Updates are available via the Autodesk Desktop App or the Autodesk Account.
This May Work,
Peter
