I have multiple users getting a "System.AccessViolationException: Attempted to read or write protected memory." error when starting Inventor 2017.
The full error is pictured below. They can close the error and work in Inventor without issue but it's extremely annoying.
I have ran Windows memory tests, fully removed (using Autodesk tool and then manually scrubbing any remaining files I could find) and reinstalled and have had no luck in getting this error to go away. One thing I did find interesting, when I fully removed and reinstalled, the error did not appear when opening Inventor before installing all available patches. Once the Inventor suite was fully patched, the message came back.
I've checked the boards and only saw a few things. One was to disable UAC and that didn't help and the other was more technical than I could understand and wasn't even sure if it was relevant (something to do with attribute values?). Any help you could provide would be greatly appreciated! TIA, Brian
