There is an option in the deployment package creation panel which says "
¡Resuelto! Ir a solución.
Resuelto por m_latz. Ir a solución.
installation of whatever Autodesk software, Autocad/LT/Revit/Civil....
Let me rephrase, what's the difference between a deployment created with symbolic links and one without?
A few Links that you may see if they help you out..
Hi Rushabh
That information is not related to my question.
It's a simple question, what's the difference between checking this option or not checking it?
A symbolic link (or "symlink") is file system feature that can be used to create a link to a specific file or folder. It is similar to a Windows "shortcut" or Mac "alias," but is not an actual file. Instead, a symbolic link is a entry in a file system that points to a directory or file.
Thank you Rushabh, is there any practical difference between checking it or not?
and what's the Autodesk recommended choice?
Actually I shared the Links that I got related to Symbolic links on Google.. I personally am not using these symbolic links...
I don't know much about Symbolic links. But got this..
July 2019 - Autodesk Licensing Service update
Improvements
At the end of this Page... https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-relea...
So, is there anyone at Autodesk that actually knows the answer to this questions? (not posting internet search results)
As far as I know, symbolic links are used to direct the installation towards a certain folder. Or add that file and link it with the software. Do you have any such file that you want to attach..?
If yes, than use a Symbolic Link. And if No, Continue without any symbolic link.
Read a comment on a post... "I've used a Windows 10 Symbolic Link to link a folder into the Fusion 360 drive for the desktop connector to sync into the cloud"..
If you create a new deployment e.g. for AutoCAD 2022, Autodesk Inventor 2022 and Autodesk Vault 2022 without the "Symbolic link option" you have .NET framework 4.8 runtime installation source in all 3 products, Material Libraries in all 3 products, ...
If you activate the "Use symbolic links" option all shared installation packages are only once in your image and all other are linked.
This reduces dramatically the size of the deployment !
regards
Markus
