Installation & Licensing
940 Views, 6 Replies
Stingray
I saw an article about the new game engine Stingray. Will that program be made available to education accounts?
6 REPLIES 6
DarrenP
it probably will be after Autodesk releases it
this is not even available to purchase yet
DarrenP
matthew.d
Hi @Anonymous,
Great question! Stingray will be made available to education accounts.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
in reply to: matthew.d
It is out now but I still can't get stingray.
I assume autodesk will fix it soon
matthew.d
Hi @Anonymous,
You can get the education version of Stingray here.
Matt DiMichele
Hi friends,
I am using Window 8 64bits and I recieve this error:
"The backend crashed unexpectedly. You can look into the latest log files to see what happened."
when I click on the button (Show logs) I've this file (stingray_log_2015-08-25 21_43_25Z.text) with these informations:
21:43:20 [Info] - Running build dc0c2c87edbff1f8fa2793096d4479a54db4fea6
21:43:20 [Debug] - 25/08/2015 21:43:20 [Info] Server started at ws://127.0.0.1:12010
21:43:20 [Debug] - 25/08/2015 21:43:20 [Info] Server started at ws://127.0.0.1:12011
21:43:20 [Debug] - Loading services took 219 ms
21:43:20 [Debug] - Application registration took 295 ms
As you can see on the file attached.
Any Idea?
I have the same problem as yours jaderbrandao.
I have change my version of Stingray to the latest one which is v 1.0.113.0 (the one that is supposed to fix the backend problem) . I opened every HTTP/TCP ports in my firewall, executed both stingray_editor.exe and StingrayEditorBackend.exe with admin rights. Should we change StingrayEditorBackend.exe.config file so that it works?
For me it's happening on windows 7 64 Bits familial edition.
I know my problem is not hardware and some people says the problem comes with the system language because the program is US, so I'm gonna try this out. I hope there will be a fix soon. Thank you Autodesk for the support.
I also have an education account and the Stingray version that comes with the product key given is the 1.0.31.0 which didn't work either.
Administrator Productivity
