Trying to install Autodesk AutoCAD 2017 on Surface pro 4
Installation cuts off early with "Installation complete. Some
products failed to install." Displays red exes on all the products.
Here's the latest installation log
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 === Setup started on DESKTOP-JKJ5J75 by larat ===
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 Path_Length: 162
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 Launch
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se...
2017/4/20:12:51:30 larat DESKTOP-JKJ5J75 Current Directory C:\Users\larat\AppData\Local\Temp\_AI4CBE.tmp
2017/4/20:12:51:33 larat DESKTOP-JKJ5J75 === Setup ended ===
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 === Setup started on DESKTOP-JKJ5J75 by larat ===
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Path_Length: 162
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Current Directory C:\Users\larat\AppData\Local\Temp\_AI4CBE.tmp
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Launch
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\larat\AppData\Local\Temp\_AI4CBE.tmp\Setup\AcSetup.dll
2017/4/20:12:51:31 larat DESKTOP-JKJ5J75 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/20:12:51:32 larat DESKTOP-JKJ5J75 PageOpen LaunchDialog
2017/4/20:12:51:46 larat DESKTOP-JKJ5J75 PageOpen LicenseDialog
2017/4/20:12:51:46 larat DESKTOP-JKJ5J75 PageOpen ProductInfoDialog
2017/4/20:12:51:46 larat DESKTOP-JKJ5J75 PageOpen ProductSelectionDialog2
2017/4/20:12:51:57 larat DESKTOP-JKJ5J75 PageOpen FullProgressDialog
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Install Universal C Runtime (KB3118401) Succeeded
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/4/20:12:51:58 larat DESKTOP-JKJ5J75 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\larat\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/20:12:51:59 larat DESKTOP-JKJ5J75 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/20:12:51:59 larat DESKTOP-JKJ5J75 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/4/20:12:51:59 larat DESKTOP-JKJ5J75 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\larat\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/20:12:52:00 larat DESKTOP-JKJ5J75 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/20:12:52:00 larat DESKTOP-JKJ5J75 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/4/20:12:52:00 larat DESKTOP-JKJ5J75 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/4/20:12:52:04 larat DESKTOP-JKJ5J75 Install DirectX Runtime Succeeded
2017/4/20:12:52:04 larat DESKTOP-JKJ5J75 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/4/20:13:02:10 larat DESKTOP-JKJ5J75 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/4/20:13:02:10 larat DESKTOP-JKJ5J75 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/4/20:13:02:10 larat DESKTOP-JKJ5J75 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/4/20:13:02:10 larat DESKTOP-JKJ5J75 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/20:13:02:10 larat DESKTOP-JKJ5J75 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Solved by Mark.Lancaster. Go to Solution.
It's a download failure.
I would recommend that you try downloading your product using the Virtual Agent by following the directions here:
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions...
When I run the download, I extracted it to C:\Autocad\, but the folder is empty. Am I supposed to be finding it here?
When I run the download, I extracted it to C:\Autocad\, but when I open the folder it's empty. I'm not sure where to go from here.
@Anonymous
When it extracted, did you see a progress bar showing the extraction or nothing happened? Extraction can take some time its not something that happens within seconds.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Disable your antivirus system, make sure your destination is set to a local drive, copy the unpacked exe to a local folder, unplug or disconnect from network and start the (unpacked) exe with a right-click ==> "start as administrator". Make sure the destination volume has enough free space. One more thing.. Can you post the file sizes of the downloaded parts. Another reason it fails is due to not having the correct file size of the downloaded parts.
Mark Lancaster
Thank you! The first time I disabled my antivirus system, nothing happened. Then I checked the file size (6.45 MB), redownloaded the first part (now 2GB) and worked! Thanks again!
I cant also install the autocad 2018. here's the log.
kindly help me solve this issue hehehehe
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201...
2018/11/4:09:41:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIA132.tmp
2018/11/4:09:44:11 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/4:09:41:31 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/4:09:41:31 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/4:09:41:31 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIA132.tmp
2018/11/4:09:41:31 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/4:09:42:52 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:42:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:42:56 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:44:06 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:44:08 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIA132.tmp\Setup\AcSetup.dll
2018/11/4:09:44:08 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/4:09:44:18 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/4:09:44:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/4:09:44:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/4:09:44:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/4:09:45:18 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/4:09:45:19 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:45:19 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:45:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:45:23 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:45:23 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/4:09:46:04 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/4:09:46:04 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/4:09:46:08 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/4:09:46:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 [Error: 1056] An instance of the service is already running.
2018/11/4:09:46:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_Trial_en-us
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine /PK 001J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_201...
2018/11/4:09:48:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI85B8.tmp
2018/11/4:09:48:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/4:09:48:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/4:09:48:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/4:09:48:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI85B8.tmp
2018/11/4:09:48:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/4:09:48:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:48:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:48:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI85B8.tmp\Setup\AcSetup.dll
2018/11/4:09:48:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/4:09:48:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/4:09:49:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/4:09:49:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/4:09:49:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/4:09:49:25 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/4:09:49:26 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:49:27 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:49:27 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{13EDBFB0-2...
2018/11/4:09:49:27 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/4:09:49:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/4:09:49:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/4:09:49:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/4:09:52:41 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Autodesk\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:11:28:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI3EF1.tmp
2018/11/5:11:29:02 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:11:28:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:11:28:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:11:28:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI3EF1.tmp
2018/11/5:11:28:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:11:28:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI3EF1.tmp\Setup\AcSetup.dll
2018/11/5:11:28:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:11:29:03 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:11:29:32 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:11:29:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:11:29:42 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:11:29:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:11:29:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:11:29:47 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:11:29:47 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:11:30:27 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:11:30:27 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:11:30:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:11:30:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:11:30:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:11:34:25 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:11:43:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIE469.tmp
2018/11/5:11:43:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:11:43:37 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:11:43:37 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:11:43:37 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIE469.tmp
2018/11/5:11:43:37 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:11:43:38 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIE469.tmp\Setup\AcSetup.dll
2018/11/5:11:43:38 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:11:43:54 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:11:44:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:11:44:16 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:11:44:16 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:11:44:33 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:11:44:34 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:11:44:52 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:11:44:52 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:11:44:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:11:46:03 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:12:13:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2018/11/5:12:14:06 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:12:13:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI490.tmp
2018/11/5:12:14:14 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:13:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:13:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:13:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI490.tmp
2018/11/5:12:13:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:13:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI490.tmp\Setup\AcSetup.dll
2018/11/5:12:13:45 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:12:14:15 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:12:14:39 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:12:14:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:12:14:43 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:12:14:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:12:14:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:12:15:12 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:12:15:12 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:12:15:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:12:15:36 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_r1_wi_en-us
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine /akamai /sid a1b3A00000DOoyGQAT /skipEULA /url "https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/AutoCA...
2018/11/5:12:34:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIFE84.tmp
2018/11/5:12:37:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:35:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:35:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:35:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AIFE84.tmp
2018/11/5:12:35:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:35:16 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play SETUPMARKER https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:35:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete SETUPMARKER https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:35:18 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play SETUP_CONFIG https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:37:28 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete SETUP_CONFIG https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:37:28 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AIFE84.tmp\Setup\AcSetup.dll
2018/11/5:12:37:28 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:12:37:32 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:12:39:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:12:39:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:12:39:48 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:12:39:58 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:12:39:59 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play STARTMARKER https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:40:00 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete STARTMARKER https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:40:00 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Play VCREDIST2008SP1X86 https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:40:03 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Download Complete VCREDIST2008SP1X86 https://efulfillment.autodesk.com/NET18SWDLD/2018/ACD/CF45550A-C6C8-4B4B-8DD7-7DEA2F285010/WI/{AAE0B...
2018/11/5:12:40:03 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:12:40:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:12:40:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:12:40:35 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:12:41:29 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:12:55:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI3084.tmp
2018/11/5:12:56:24 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:12:56:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:12:56:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:12:56:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI3084.tmp
2018/11/5:12:56:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:12:56:02 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI3084.tmp\Setup\AcSetup.dll
2018/11/5:12:56:02 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:12:56:25 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:12:56:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:12:56:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:12:56:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:12:57:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:12:57:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:12:57:49 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:12:57:49 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:12:57:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:12:58:03 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/5:13:57:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI5012.tmp
2018/11/5:13:57:37 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/5:13:57:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/5:13:57:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/5:13:57:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI5012.tmp
2018/11/5:13:57:17 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/5:13:57:18 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI5012.tmp\Setup\AcSetup.dll
2018/11/5:13:57:18 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/5:13:57:38 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/5:13:57:53 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/5:13:57:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/5:13:57:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/5:13:58:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/5:13:58:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/5:13:58:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/5:13:58:20 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/5:13:58:24 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/5:13:58:30 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/6:09:54:05 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI14AC.tmp
2018/11/6:09:54:39 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI14AC.tmp
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI14AC.tmp\Setup\AcSetup.dll
2018/11/6:09:54:13 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/6:09:54:40 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/6:09:54:58 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/6:09:55:02 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/6:09:55:02 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/6:09:55:07 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/6:09:55:08 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/6:09:55:34 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/6:09:55:34 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/6:09:55:39 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen InstallCompleteDialog
2018/11/6:09:55:51 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 CommandLine
2018/11/6:10:00:55 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI54C5.tmp
2018/11/6:10:01:15 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup ended ===
2018/11/6:10:00:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 === Setup started on DESKTOP-RH4U4L8 by DELLINSPIRON CORE I5 ===
2018/11/6:10:00:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Path_Length: 158
2018/11/6:10:00:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Current Directory C:\Users\DELLIN~1\AppData\Local\Temp\_AI54C5.tmp
2018/11/6:10:00:57 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Launch
2018/11/6:10:00:58 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DELLIN~1\AppData\Local\Temp\_AI54C5.tmp\Setup\AcSetup.dll
2018/11/6:10:00:58 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/6:10:01:10 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LaunchDialog
2018/11/6:10:01:23 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen LicenseDialog
2018/11/6:10:01:26 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductInfoDialog
2018/11/6:10:01:26 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen ProductSelectionDialog2
2018/11/6:10:01:46 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 PageOpen FullProgressDialog
2018/11/6:10:01:46 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Users\DELLINSPIRON CORE I5\Desktop\AutoCAD_2018_English_Win_64bit_Trial\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/6:10:02:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Microsoft Visual C++ 2008 SP1 Redistributable (x86) return code: 1603
2018/11/6:10:02:01 DELLINSPIRON CORE I5 DESKTOP-RH4U4L8 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
