Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Solutions for Error 0xc000007b
0 RESPUESTAS 0
Responder
Mensaje 1 de 1
SerdarHakann
3432 Vistas, 0 Respuestas
Solution 1: file corruption or deletion of .Net Framework
If this is the case, you will need to reinstall the .NET Framework applications to solve error 0xc000007b.
.Net Framework is an application framework necessary for many Windows applications.
Solution 2: corruption or deletion of 0xc000007b error that application file
If you get this error, reinstalling the program is a possible solution for error 0xc000007b.
Solution 3: Virus/Malware affecting your computer
Malicious software such as computer viruses or malware can infect 0xc000007b and cause this error. In this case perform a full system anti-virus and anti-malware scan.
Solution 4: Run the application as an administrator
Right-click the shortcut of the program which could not be started properly due to error 0xc000007b error. Go to properties. Select the Compatibility tab and tick the “Run the application as administrator” option.
Some applications require administrator privileges in order to work properly. By selecting the option above, you will be given administrator rights whenever you run this particular application.
Solution 5: Restart the computer.
If you are experiencing error 0xc000007b for the first time with an application which normally starts without errors, restart your computer. A bad computer boot can cause temporary problems which are easily solved with a system restart.
Solution 6: Reinstall missing or incorrect Window updates.
Go to Windows Update on the Control Panel and install the available updates. Missing Windows updates can cause problems.
Solution 7: Check for updates for the affected application.
Check the application’s website for any updates for the application being affected by error 0xc000007b . Programs can sometimes have compatibility issues with different versions of the Windows operating system. For example, applications running smoothly on Windows 7 may not run properly on Windows 8. Make sure you install application updates which can correct this behavior.
Solution 8: Missing or incorrect Microsoft Visual C ++ 2010 library
Many applications require the Microsoft Visual C ++ 2010 library. If your Microsoft Visual C ++ 2010 libraries are missing or damaged, you may receive the error “Application failed to initialize properly”. This can be corrected by downloading Microsoft C++ 2010 for your 32-bit system or your 64-bit system.
You will need to restart your computer after installation.
Solution 9: DirectX corrupted or missing
If the application is a program that used to start properly, error 0xc000007b error may be solved by reinstalling DirectX.
Serdar Hakan DÜZGÖREN
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ile ödüllendirin.
3D Generalist |Serdar Hakan.NET | Serdar Hakan AKADEMİ |
serdarhakanakademi
0 RESPUESTAS 0
Publicar en los foros
Administrator Productivity
