Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Slow Donwload Speed of the installer
1 RESPUESTA 1
Responder
Mensaje 1 de 2
andrea8dali
290 Vistas, 1 Respuesta
Hi, Im trying to download Autocad Installer, but the download speed is really slow, my wifi is ok, everything else works great, except this download. I already downloaded and installed Revit, but I got this problem with Autocad. I also tried to do the same operation in an another PC but is the same.
Etiquetas (1)
1 RESPUESTA 1
Mensaje 2 de 2
TravisNave
en respuesta a: andrea8dali
You might try the 2024 Direct Links thread and get the AutoCAD 2024 installer from there.  And then you can add the Italian language pack to that if necessary.
https://forums.autodesk.com/t5/installation-licensing/2024-product-download-links/td-p/11835996
Good Luck!
Autodesk Forums:
Publicar en los foros
Administrator Productivity
