silent install using web installer and preconfigured revit.ini
I'm doing a skript for silent company wide deployment of Revit 2023.1.2.... There are many issues in the forums having several issues when doing such a thing, I know.
(I'm using the customized setup in the Autodesk Mangage environment, use the (web-)downloader to deploy to the machines. In this case I'm trying for the first time to really use this web installer, and I'm no longer extracting the image from the installer and deploying the whole 15GB to each machine...)
My issue is more or less an information directly for autodesk:
When customizing the (web) setup I have to use the option to deliver a customized revit.ini file, as we want to give alternative template paths (and do NOT want to have the installer putting things into these folders). The issue is that if I upload a customized .ini this ini is usually coded as a windows file. But Autodesk makes it a UNIX file when it fetches it back to the client (creating the image). (see attachment)
As a result Revit takes this unix ini from the Programdata... UserDataCache folder and copies it to the %appdata%\autodesk... Folder of the user, 'converting' it back to windows, but generating issues for all 'special characters' (mutated vowels, umlaut).... which is visible for instance in the template selector within Revit.
