Hello @Mohamed_Bakr,
Does this issue just pop up or does it happen after you access something on the system?
It seems its related to files created by anti virus software. Please review this related link:
Windows Script Host error popping up, Can not find script file
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
I hope you had the chance to review the information I provided. Keep me posted on the progress. ![]()
Natasha
Helpful Links:
Doh! A quick google for 'service.vbs' shows it is part of a crack for Autodesk software. Here is an analysis of the crack that installs service.vbs:
Were you able to get this resolved? If so, can you share how?
i managed to solve this problem by Making the folders Path by creating new folders and naming it just like as the path given in the error message
then creating a text file and type in it this text " Wscript.Quit " then save it in the created path the chnge the file extension ton .vbs instead of .txt
that solved my problem and let me know if this method helped you too
Best Regards,
Abdulrahman Yasser
The .VBS file is not part of valid Autodesk software. It is part of an illegal crack for Autodesk software that was previously installed. Here is the right way to fix:
I am having the same issue
I have been trying to install AutoCAD 2023 or 2024 but every time it asks my laptop to restart and after restart this error pops up
You can do the same solution I mentioned above It will work ISA
Best Regards,
Abdulrahman Yasser
Create a text file named service on your desktop and change the file suffix from.txt to.vbs. Then copy the error path to the folder in the C:\Program Files (x86)\Common Files\Autodesk Shared\Network License Manager path
Bunu da denedim ama autoruns.exe'de herhangi bir VBS dosyası bulamadım
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
