Announcements
serial number
serial number
i tried to install the student lisence of autocad. however, i donot have the serial number. i doenloaded the 2022 version however, the installation asks for the serial number and im not able to locate it. please help
Check if your subscription is serialised:
Product activation | Download & Install | Autodesk Knowledge Network
If not, choose the "Sign in with Autodesk ID" option.
If it keeps asking...
  • When you launch the product and are greeted with this screen, click on the “Run” button:
  • When the software loads up, click on the little down arrow to the right of the question mark in the top right corner of the software and select “About Autodesk <product name>” from the dropdown:
  • Click on “Manage license”:
  • Click on the “Activate” button:
You should then see this screen:
  • Click on “Sign in with your Autodesk ID” and provide your Autodesk account credentials.
