"I just cannot find my serial number and i am signed in
thats because autodesk is doing away with serial numbers
so whats the problem?
DarrenP
I have a paid subscription and I downloaded 2022 and it still says unregistered version.
Hi @hvcprecast,
On Revit, click on your username then manage license,
What do you see?
Do you see your license? If not click change license.
everything is ok when I open 2021 version, but when I open 2022 it says unregistered version , I am a single user ā
Make sure you are signing in with the email address you are assigned to the license under. Installing licensing updates and the Single Sign On update and performing a license reset might help. If not, contact Autodesk support for assistance as it might be a sync issue.
ĀæNo encontraste lo que buscabas? PregĆŗntale a la comunidad o comparte tus conocimientos.
