Our network license is for 7 Revit Structural Suites 2014 and 2 Acad 2014.
We currently use 2012 ACAD and 2011-2013 Revit Structure.
8 computers access ACAD 2012 through a Revit Structure 2012 installation and Revit's ACAD 2012 shortcourt, and 1 computer access ACAD 2012 through a regular ACAD 2012 installation. All are installations runs on a network license.
We typically run 2-3 Revits of different flavors (2011-2014) at a time and the balance of of the users run ACAD 2012. Lateley an error code-4.132.0. "a valid license could not be obtained by the network license manager" is given when a 8th or 9th users attempts to open ACAD 2012. The LMTolls shows 7 of 7 RSU used and 1 if 2 ACAD license used. Does the Revit's ACAD 2012 cascade down to ACAD2012?
PS foru
do you mean building design suite 2014?
this is an issue
DarrenP
you need to install autocad from the suite using the suite product key
DarrenP
1 computer is installed with ACAD 2012 only for a light users. 8 computers are installed with RSU 2012. Some of the 8 computers have installations of RSU 2011 and or 2012. The 8 Computers access ACAD 2012 through the Revit Suite installation. When the 8th or 9th. when the 8th or 9th computer tries to obtain a licens to use ACAD 2012 through the RSU 2012 installation we ger the error.
what does the flex lm log say?
are they getting denied a license
DarrenP
10:04:36 (adskflex) DENIED: "66000REVSU_F" rworrell@RWORRELLCOMP (Licensed number of users already reached. (-4,342))
10:04:36 (adskflex) DENIED: "85792REVSU_2012_0F" rworrell@RWORRELLCOMP (Licensed number of users already reached. (-4,342))
are your users running multiple versions of revit on the same machine?
DarrenP
One occurance of an Autodesk product per computer. I run around the office, look and yell at the users if the use more.
Just install regular ACAD 2012 on my machine. Regular ACAD 2012 will obtained a license. I closed out of ACAD 2012, clicked on Revit's ACAD 2012 Icon which resulted in a denial of license.
try deleting or renaming this file:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9240657
DarrenP
if the above doesn't work
the only other thing i can think of is were the revit suite license and the autocad licenses generated the same day?
DarrenP
