Revit
Revit
I'm trying to install revit but every time that i try, it lasts too much and it doesn't instal Revit families. How can I do?
Mark.Lancaster
@Anonymous
Welcome to the community..
Not sure what you mean it last too much.   How are you installing Revit?  Install now?  Have you tried the Autodesk Virtual Agent Method?
If not please follow these steps:
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
