Revit Install Issues
wol000
wol000
I'm trying to install a student version of Revit on my computer. I've been reading through a lot of the queries to date, but can't find any info on the one I'm having unfortunately. I can't get it to install unfortunately
My computer runs with windows 8.1 & it's 64bit. From scrolling through previous threads I believe I need to download Revit15 would i be correct?
Prior to install I've checked "ïnstall tools & utilities" & the Revit Server is advising that i'm not meeting the systems minimum requirements and I need to install "windows server 2008 R2 SP1",
I've tried to download this, but my computer is advising i already have this update.
Am I doing something silly on install. Any info would be appreciated as its a bit beyond me. Thanks,
ukdxb012
Revit Server can only be installed on Windows Server operating system. Usually this is a dedicated workstation or server with the OS installed so that multiple users can connect central models to in order to work share over a WAN.
You do t need this if its just yourself using the software.
As for Revit 2015, this can be installed on the following OS's...
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
wol000
Hi Duncan,
Thanks for explaining that. I tried to do a quick install again & I'm getting a pop up. It's advising I re-install due to a connection or firewall issue, but i dont think its either of these things. Is there an easy fix for this. Thanks,
ukdxb012
Yes there is, on the screenshot it recommends for you to download another way. The most successful way to download Autodesk products is via the Browser Download option. You can use Autodesk Account, Education Centre or the Autodesk Virtual Agent to do this but make sure you chose the Browser Download option and not Install Now or Download Now.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Good Luck!
Duncan Brannan
Twitter | LinkedIn
wol000
Thanks Duncan
ukdxb012
You're welcome!
Duncan Brannan
Twitter | LinkedIn
I tried brower download instead of install now or download now and i still got the same error saying that revit servers needs to be installed with a windows server 2008 r2 sp1. I thought i was compitable. please help I got a new computer for school cause my last one crashed on me. I finals coming up soon I need to know if this works or not so i can exchange it for one that does. I have a Windows 8.1 deskstop. My name is Eddie
