Revit Error '' Autodesk Revit has Stopped Working'' - 2018 version
Message 1 of 9
HELP!  When I open Revit 2018 - after it loads I instantly get this message, "Autodesk Revit has stopped working".  I have tried all solutions found online. The first time when that happened was after Windows 10 Update. Before that Revit worked. Any ideas what can i do to fix the problem?
Thanks!
Replies (8)
Message 2 of 9
cbcarch
Take a look here: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-software-does-n...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 9
Thank you! I tried everything but it still gives me the same error message.
Message 4 of 9
Viveka_CD
Hi @Anonymous
Please see solutions in this article and this thread
If this does not help please send us your Revit journal file to test further.
Let me know if you have any questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 5 of 9
Thank you! I tried everything, but it didn't help. I also uninstalled Revit again and now when i try to install it - after the installation is over i get the message that part of the installation failed. I'll send you screenshot of it later. I tried to install Revit 2019, but during the installation, i get the message that i can't - and when i tried to send you report, it gives me error again - I send you screenshots. Do you have any ideas what can I do? It is not the computer parameters
Message 6 of 9
Viveka_CD
Hi @Anonymous I'll move your post to the installation forum for further feedback. Please add screenshots and details to test further. Regards,
Message 7 of 9
The messages that i get when i try to install REVIT 2019
Message 8 of 9
And the messages that i get when i try to install REVIT 2018
Message 9 of 9
And more pictures of the messages that i get when i try to install REVIT 2018
