Revit 2024 doesn't start, errors out
mmilani5781
Observer Observer
mmilani5781
Observer
Observer
Hi Everyone,
A brand new installation of Revit 2024 doesn't start and produces the following error.
I appreciate any pointer on how to fix this.
Thanks.
Application: Revit.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: mscorlib.dll
Exception Address: 0x00007ffd162e9a78
Exception Code: c0000005
Exception Flags: 80
Exception Parameters: 0, 10
Managed Exception Type: System.NullReferenceException
Managed Exception Address: 0x000001e80d2b4cd0
mmilani5781
Observer
Observer
To add that on the same machine, AutoCAD 2024 runs fine.
mmilani5781
Observer
Observer
Downloaded the 2024.1.1 Update for Revit released 9/5/23 from the Autodesk website, and now Revit opens, but gives four windows one after another about Failed to initialize the add-in "Batch Print"  / "eTransmit for Revit" / "Worksharing Monitor Application" / "Worksharing Monitor Launch App" because the assembly *** does not exist.".
But these probably don't matter for regular use of the tool.
km4504
Does anyone get this message for Revit 2024.1.1?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
mdavis22569
Few are reporting this
Reinstall the c++/net
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinst...
Mike Davis
cbellamyHYNEM
Community Visitor
Community Visitor
I am getting this error and I dont know what it means. Also I am trying to update to the most receny version of Revit but the download goes to 97% and stops even if I leave it runig overnight.
esk0r
Could be a few things but first of all, check that you have all updates installed for that version of Revit.
Follow suggestions from this post to troubleshoot further: "Revit has stopped working" when launching Revit - Event Log shows: Faulting module path: C:\WINDOWS...
Rene Pellicer Garcia
