'Revit 2023.1.1 Update' will not install.
ttooc2
ttooc2
Try 1. I also tried uninstalling and reinstalling.
try 2. Updated from Autodesk App.
try 3. I also tried downloading a custom installer.
All three of the above attempts do not work. Current version is 23.0.20.21 with hotfix installed. How can I update to 2023.1.1?
cadffm
handjonathan
Hi @ttooc2
Thanks a lot for posting your question to the forums!  
For the community to help you best, it would be great to have more details from your end.  
• Any error messages showing the install fail
• If possible, can you add screenshots or attach a video showing the issue?  Info on how to add a video can be found here.
I look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
rushabhthakkar_910
@ttooc2, Can you be more specific with what is your exact issue to help you better and quiker.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
DarrenP
another thread on this: https://forums.autodesk.com/t5/installation-licensing/revit-2023-1-instalation-error/td-p/11559113
DarrenP
m_latz
oops wrong thread.
ttooc2
I removed 'AIM'. And the 2023.1 update was completed. thank you.
