Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Revit 2021 fails to install with an error code 1603
4 RESPUESTAS 4
RESUELTAS
Responder
Mensaje 1 de 5
lawrenceville.dravasco
7008 Vistas, 4 Respuestas
Revit 2021 starts installing well up to a point and fails just past the licensing service installation but during the Revit 2021 core content install. I've attached the install logs.
Etiquetas (4)
4 RESPUESTAS 4
Mensaje 2 de 5
Your install log file included the following:
Running helper with params: "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\10.1.0.3194\helper\AdskLicensingInstHelper.exe" upgrade isUpgraded
LicensingCustomAction.licIsSvcUpgraded [I] [17:14:08:625]: process exit code: 106
LicensingCustomAction.licIsSvcUpgraded [E] [17:14:08:626]: exit code: 0, output: Error: The specified service does not exist as an installed service.
This lines up with description that the install failed during licensing service installation.  My initial suggestion would be to see if the following folder exists on your system: C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing.  If so, run the uninstall.exe file located in this folder to remove the currently installed version of this component.
If that doesn't resolve the problem, then I recommend checking out this article, which covers how to download and install the latest version of the Autodesk licensing service.
Tony Michniewicz
Revit Software QA Analyst
Mensaje 3 de 5
Please attach the article @Tony_Michniewicz
Mensaje 4 de 5
I apologize for forgetting to post the link that I had mentioned previously.  Here it is: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Autodesk....
Tony Michniewicz
Mensaje 5 de 5
en respuesta a: Tony_Michniewicz
Hey you solved my issue aswell.
Thank you so much for your help, I have been struggling on it for hours and I have a deadline in a few days!
Thanks again
Publicar en los foros
Administrator Productivity
