Hello Good morning, I came in looking for help since I have been trying to install revit 2017 for days, it gave me a lot of problems and today I was able to install it, when I try to open it it gives me an error "Revit has stopped working" windows is looking for a Solution to the problem I do not know why this is what I read in forums and I only find vague answers. !!I have Windows 7!!
As background had already installed Revit 2013 and 2015 and worked correctly without problems; A few weeks ago I tried to install Rhinoceros and from there started the problems since I unistall the .NET.Framework and reinstall them to work anyway threw error that the .NET.Framework 4.0 was not installed since those changes could not open Revit, the icon changed and came out with a shield.
I checked the antivirus in case of malwae, I installed revit 2017 and the icon comes out normal, I have repaired the visual ++ cc, update the windows Update, I have the Servi pack 1 and 2 updated, I reinstalled the .NET.Framework I have even entered the CMD Sfc / scannow to corroborate if there are errors and I have not had a solution with this problem, it is necessary to emphasize that other programs like AUTOCAD, programs of the line of Adove among others of design that use the same characteristics work correctly. If you have a solution to this problem, I would appreciate it.
Solved by natasha.l. Go to Solution.
Hello @Miguel7navas,
Please check and make sure you meet the System requirements for Autodesk Revit 2017 products.
Let us know what you discover. Thank you for posting.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
