When I try to run these updates with the command line switch /Q or /passive nothing happens. I know this works on some systems but I have atleast 2 here that it doesn't. I'm running with Windows 7. Anyone else experiencing this?
Hello @kd5914,
Sorry to hear that, are you trying to apply these updates in a facility where the may have the command script disabled. Educational Institutions sometimes restrict this from users.
Please report back on your findings, thanks for posting.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @kd5914,
I wanted to follow up with you, I hope you were able to resolve the issue.
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Thank you.
Natasha
Helpful Links:
I am having an issue installing this patch on some (not all) of our workstations. I am using the silent switches to install the patch and it seems to take a long time to load and unpack.
Can someone tell me the proper use of the /layout switch so I can extract the bundle to a folder? I would like to run each of the bundled updates separately but when I use that switch it only extracts the Revit Update executable and not the entire contents of the update.
SLGear
