Installation & Licensing
Revit 2015 Trial Will Not Run
1 REPLY 1
jyaung
416 Views, 1 Reply
The Revit 2015 Trial closes immediately and refuses to run the application.
We have tried a complete uninstall and clean install, as described in the troubleshooting.
This is the error:
Faulting application name: Revit.exe, version: 2015.0.2014.606, time stamp: 0x5398bede
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18409, time stamp: 0x5315a05a
Exception code: 0xe06d7363
Fault offset: 0x000000000000940d
Faulting process id: 0x167c
Faulting application start time: 0x01d029d5ae950046
Faulting application path: C:\Program Files\Autodesk\Revit 2015\Revit.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: ec4fd35f-95c8-11e4-aa4f-1803734e61bf
All system requirements are met
1 REPLY 1
dembkod
in reply to: jyaung
jyaung
Hello. This could be a few things. It is a KERNELBASE error, which is usually something out of sync on the Operating system.
Uninstall the NET and Microsoft entries and then try to reinstall. This may help. If not, update the graphics card drivers and check the Windows Event log to see if there is an additional log in there pointing to something specific.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
