Installation & Licensing
Revit 2015 and Revit 2016
6 REPLIES 6
1024 Views, 6 Replies
Can I install and run Revit 2015 and Revit 2016 on the same computer.  Some of my practice files are 2015 from my old laptop - now I have 2016 on my new laptop and need to put 2015 on the new laptop as well so I can work on the old files also
6 REPLIES 6
TravisNave
Yes you can so long as you are under active Subscription.  Just keep in mind that Revit is not backwards compatible.
Good Luck!
Autodesk Forums:
pendean
You cannot open REVIT 2016 files in REVIT 2015 at all: do you understand what that means?
in reply to: TravisNave
Hello TravisNave,
I have a similiar question regarding the installation of Revit 2015 (student version) and Revit 2016 (student version) on the same computer. My school currenty upgraded from Revit 2015 to 2016. Unfortunately, I have Revit 2015, and I learned the "hard way" that Revit 2016 is not backwards compatible.
I currently have a three year license (little over two years is left) with Revit 2015. I'm wondering if the installation of Revit 2016 on the same computer might cause compatiblity issues or worse? What if the simplier strategy is to uninstall Revit 2015 and install Revit 2016?
Thanks for the help and suggestions,
Darren
himmellm
I currently have/use Revit 2015.
My instructor insists I have Revit 2016 for her class.
I don't want both.
How do I transition to Revit 2016? Is it automatic when I install it?
I want Revit 2015 to be replaced by the new version.
thanks, lmh
TravisNave
in reply to: himmellm
The install doesn't replace the old version. But Revit is not backwards
compatible so you can only use 2016.
Autodesk Forums:
himmellm
So...I should specifically: uninstall revit 2015? (Because, I don't need it
anymore and don't want the redundancy taking up space.)
Thx, LMH
Sincerely yours,
Laurel Molly Himmel
Department of Architecture + Interior Design
Miami University
Master of Architecture 2017
himmellm@miamioh.edu
Administrator Productivity
