I have a stand alone license for Autocad LT 2009 but the old computer it was on is dead. I have the original PLU from when i put the license on the old computer. Can that be used to create a new PLU for my new computer. Also i don't know what the serial number is because it shows up as 000-0000000
Tim
If you tried transferring the license from one system to another but the license doesn't get downloaded onto the new machine, it's due to one of the following:
That being said, once those issues are corrected on the destination machine (serial number, or software mismatch), you should be able to copy down the transferred license.
If after making the changes still doesn't work, just activate the software on the destination machine.
Note: If you activate the new machine, make sure you uninstall the software from the old machine along with deleting the following directories:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
I never got a chance to export the license from the old computer before it died. The PLU i have is the license i used to put on the old dead computer.
@Anonymous
If you don't know your serial # you will have to contact (chat with) Autodesk customer service. Without it you will not be able to activate your product. Also AutoCAD LT 2009 is not really supported by any of the new operating system Not saying it will not work but you may have issues installing and using the product. It may be time for your to upgrade (rent) to a later version of LT..
Mark Lancaster
& Autodesk Services MarketPlace Provider
