"FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at 4FACC334h"
sumitbhukal007
Message 1 of 10
sumitbhukal007
I had some licensing problems with my Autocad. I don't know what was the problem it just start showing the license expire. I have full one-year access under the 'Student' category. Then after some time, I uninstalled the program and again downloaded and installed it. But it is now showing a new error, it's not even opening now.
Please solve this problem
Replies (9)
Message 2 of 10
mdavis22569
Is it installed and just now starting up now?
If so, what do you have for your video card and driver?
Try this:
https://knowledge.autodesk.com/support/autocad/getting-started/caas/simplecontent/content/starting-a...
After you do that, click on the Run as Admin option and then see if that works for you
Mike Davis
Message 3 of 10
sumitbhukal007
I tried this method but it's now showing this error
' FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at CBF8C3344 '
Message 4 of 10
sumitbhukal007
It's still not working.
Message 5 of 10
mdavis22569
Mike Davis
Message 6 of 10
sumitbhukal007
I have an AMD Radeon Graphic card.
Message 7 of 10
mdavis22569
So I think there are around 100 and some AMD cards.  Not going to guess
Can you share the model and driver number.   You can get that from your DXDIAG dialog box ... under displays.
Mike Davis
Message 8 of 10
sumitbhukal007
AMD Radeon(TM) Graphics and the driver version is 30.0.13044.0
Message 9 of 10
mdavis22569
If you have a basic AMD Graphic and not one listed here:
https://knowledge.autodesk.com/certified-graphics-hardware?id=18844534&siteID=123112
then likely as I was mentioning earlier you have a graphics card conflict / issue.
Try this:
Mike Davis
Message 10 of 10
sumitbhukal007
I tried everything but don't know why the 2021 version worked for me. And thanks for the support.
