"Error 11" when installing inventor
christian_sauerUNMHB
Observer
Observer
Observer
Hello dear community,
I'm trying to install Autodesk Inventor (I tested 2025 and 2023) on my computer, but I keep getting an "error 11" message. I've searched everywhere but can't find any information on what this error means or how to fix it.
Has anyone here encountered this error before or knows what might be causing it? Any help would be greatly appreciated!
Very best
Christian
johnsonshiue
Hi! Please take a look at the following article and see if it helps.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-install-...
Many thanks!
Software Test Engineer
handjonathan
Hi @christian_sauerUNMHB
Thanks a lot for posting your question to the forums!   Has the solution suggested by @johnsonshiue helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Observer
Observer
Hi Jonathan, hi Johnson,
First of all, thank you for your help. I suspect that the problem lies in the company's internal guidelines, which interfere in some way with the communication required for licensing. Unfortunately, I don't know exactly yet, as I'm still looking for the exact meaning of ‘Error 11’.
I'll keep you posted if I find more information here.
Many thanks and best regards
Christian
