PROPERTIES - "UNKNOWN COMMAND"
I recently downloaded an update for AUTOCAD 2018 LT.  Now I can't access the properties box.  Normally I access it from the "right click" pop up menu. Since the update, when I click on "properties" from this menu, it tells me "unknown command."  What happened, and how do I fix this?
rkmcswain
Sounds like your support paths may be messed up.
Try resetting your profile.
Or maybe this:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-Unknown-Command-wh...
R.K. McSwain     | CADpanacea | on twitter
natasha.l
Hello @Anonymous,
Here is the information for a reset to defaults in AutoCAD. Hope this works for you, let us know if you need some more help. Smiley Happy
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
