Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Product License Activation on every startup
3 RESPUESTAS 3
RESUELTAS
Responder
Mensaje 1 de 4
mec4tto
952 Vistas, 3 Respuestas
Hello guys,
Every time I launch Maya I get an activation request although I click activate and get a "License Active" every time.
This thing started about 3 days ago and the timer is still ticking for some reason.
I am an active student so that should not be the issue.
Any easy solutions for this?
Thank you
Etiquetas (2)
3 RESPUESTAS 3
Mensaje 2 de 4
mdavis22569
en respuesta a: mec4tto
What happens if you Right Mouse Click on the Maya Icon and say RUN as ADMIN and activate it... so it stay?
I would also look at the following:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/You-Au...
Mike Davis
Mensaje 3 de 4
mec4tto
@mdavis22569 Thanks for the quick reaction.
Actually what helped was just to sign out of the account through Maya and log in again.
I have tried that like 4 times before that and nothing, but for now it seems to help.
I will update if it goes wrong again.
Thank you!
Mensaje 4 de 4
mdavis22569
What do you have for your Anti-Virus / Firewall?
I would also review the following:
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Which URLs/Protocols need to be white listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
You also want to make sure you have full permission to the following folders
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk *
C:\ProgramData\FLEXnet
C:\ProgramData\Autodesk
Mike Davis
Publicar en los foros
Administrator Productivity
