Thanks very much for the help Mark & Darin,
I had to go out of the office yesterday, so I am trying your ideas this morning, but I am still in trouble I'm afraid!
So, I did what you both suggested, and downloaded the files to a folder I created on the desktop. Then you said to click on the .exe file, but they are all .exe files - so Mark, I followed your lead with the numbering and clicked on the "001" file and clicked "run".
This seemed to be working for a while but then failed with the below message. I'm afraid I am not good at this sort of thing, so I am going to need your help again.....pleeeeeease.
Also, Autodesk e-mailed me when I didn't reply to your posts on here, to see if I needed more help or if the issue was resolved. I clicked the option for more help, but that too failed to load - another note popped up saying that something failed and that maybe a pop-up blocker was preventing it from working. I checked (knowing that I turned the pop-up blocker off yesterday, and yes - it IS off. I switched off the ESET internet protection & firewall, and tried again, still the same! Honestly, sometimes I really hate computers!!!!!
This is the error I got from the 2017 .exe file failing to run :
OK - now this won't work - I can't get the pic to load on here or attach below.....grrrrrrr!!!!
The message said : "ERROR. The extraction is complete. Installation could not be started. Please launch the installer manually."
So, how do I launch the "Installer" manually ?
Thanks again,
Denis.
