Installation & Licensing
*Aston, Bill
Post 1 of 2
Problems with A2K Network Installations
212 Views, 1 Replies
09-28-1999 04:30 PM
<<< Message <7sqsip$pci23@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.2000general' on Tue, 28 Sep 1999 12:06:43 -0500.>>>
I have a network installation image created on an NT network. When running
the setup from the server to the client, I get an error in the installation
box after or during the Copying Shared DLL files. "Error, unable to copy
files".
When I receive this error, the dialog box goes away and the entire installed
A2K directory gets deleted.
This does not happen on all installations however.
One note: R14 is still loaded on the client and the client user has
administrator rights.
The client PC's is NT 4.0.
What to try?
Highlighted
*[Autodesk], jerry milana
Post 2 of 2
Re: Problems with A2K Network Installations
09-29-1999 09:24 AM in reply to: *Aston, Bill
Bill,
This usually happens for one of two reasons. First, an application or service has DLLs locked that AutoCAD needs to update. Check task manager and
make sure nothing is running that you do not know about. Second, virus checkers are known to cause this havoc during install. If you are using
virus software, try disabling it prior to starting setup.
Jerry Milana,
Autodesk Product Support
> files".
> What to try?
Post to the Community
Have questions about Autodesk products? Ask the community.
New Post
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
