2019/4/30:19:32:17 Kristen DESKTOP-JO467M5 === Setup started on DESKTOP-JO467M5 by Kristen ===
2019/4/30:19:32:17 Kristen DESKTOP-JO467M5 Path_Length: 113
2019/4/30:19:32:17 Kristen DESKTOP-JO467M5 Current Directory C:\Users\Kristen\AppData\Local\Temp\_AI8092.tmp
2019/4/30:19:32:17 Kristen DESKTOP-JO467M5 Launch
2019/4/30:19:35:24 Kristen DESKTOP-JO467M5 Download Error Network error SETUP_CONFIG
https://efulfillment.autodesk.com/NetSWDLD/2020/ACDLT/7F468CAC-1BC9-4C74-8B11-E85973E5059E/WI/AutoCA...2019/4/30:19:35:24 Kristen DESKTOP-JO467M5 There was a problem downloading the software. Try downloading from a browser or installing the software from Autodesk Account.2019/4/30:19:36:25 Kristen DESKTOP-JO467M5 === Setup ended ===
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 === Setup started on DESKTOP-JO467M5 by Kristen ===
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 Path_Length: 113
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 Current Directory C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_wi_en-us
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 Launch
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 CommandLine /PK 834L1 /SN XXX-XXXXXXXX /akamai /directUrl
https://efulfillment.autodesk.com/NetSWDLD/2020/ACDLT/7F468CAC-1BC9-4C74-8B11-E85973E5059E/SFX/AutoC... /sid a1b3A00000Dn8B4QAJ /skipEULA /skipPI /url "
https://efulfillment.autodesk.com/NetSWDLD/2020/ACDLT/7F468CAC-1BC9-4C74-8B11-E85973E5059E/WI/AutoCA..."
2019/4/30:19:32:15 Kristen DESKTOP-JO467M5 Current Directory C:\Users\Kristen\AppData\Local\Temp\_AI8092.tmp
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 === Setup started on DESKTOP-JO467M5 by Kristen ===
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 Path_Length: 113
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 Current Directory C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 Launch
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 CommandLine
2019/4/30:19:42:53 Kristen DESKTOP-JO467M5 Current Directory C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp
2019/4/30:19:42:57 Kristen DESKTOP-JO467M5 === Setup ended ===
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 === Setup started on DESKTOP-JO467M5 by Kristen ===
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 Path_Length: 113
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 Current Directory C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 Launch
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\Setup\AcSetup.dll
2019/4/30:19:42:55 Kristen DESKTOP-JO467M5 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2019/4/30:19:42:57 Kristen DESKTOP-JO467M5 PageOpen LaunchDialog
2019/4/30:19:45:40 Kristen DESKTOP-JO467M5 PageOpen LicenseDialog
2019/4/30:19:45:44 Kristen DESKTOP-JO467M5 PageOpen ProductInfoDialog
2019/4/30:19:45:44 Kristen DESKTOP-JO467M5 PageOpen ProductSelectionDialog2
2019/4/30:19:45:46 Kristen DESKTOP-JO467M5 PageOpen FullProgressDialog
2019/4/30:19:45:47 Kristen DESKTOP-JO467M5 SetupUiUtil::IsDriveSSD: path is C:\Program Files\Autodesk\
2019/4/30:19:45:47 Kristen DESKTOP-JO467M5 Installing DirectX Runtime: "C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2019/4/30:19:45:48 Kristen DESKTOP-JO467M5 Installing Autodesk Licensing: "C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\x86\AdskLicensing\AdskLicensing-installer.exe" --mode unattended --unattendedmodeui none
2019/4/30:19:46:08 Kristen DESKTOP-JO467M5 DirectX Runtime return code: 0
2019/4/30:19:46:08 Kristen DESKTOP-JO467M5 Install DirectX Runtime Succeeded
2019/4/30:19:46:09 Kristen DESKTOP-JO467M5 Installing Autodesk Material Library 2020: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD LT® 2020" SETUP_PACKAGECODE={28B89EEF-3009-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={7F468CAC-1BC9-4C74-8B11-E85973E5059E} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:46:16 Kristen DESKTOP-JO467M5 Autodesk Licensing return code: 0
2019/4/30:19:46:16 Kristen DESKTOP-JO467M5 Install Autodesk Licensing Succeeded
2019/4/30:19:46:16 Kristen DESKTOP-JO467M5 Installing Autodesk Desktop App: "C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\x86\ADSKAPP\AdApplicationManager-WebInstaller.exe"
2019/4/30:19:46:23 Kristen DESKTOP-JO467M5 Install Autodesk Material Library 2020 Succeeded
2019/4/30:19:46:24 Kristen DESKTOP-JO467M5 Installing Autodesk Material Library 2020 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD LT® 2020" SETUP_PACKAGECODE={28B89EEF-3009-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={7F468CAC-1BC9-4C74-8B11-E85973E5059E} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:46:30 Kristen DESKTOP-JO467M5 Install Autodesk Material Library 2020 - Base Image Library Succeeded
2019/4/30:19:46:31 Kristen DESKTOP-JO467M5 Installing Save to Web and Mobile Feature: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD LT® 2020" SETUP_PACKAGECODE={28B89EEF-3009-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={7F468CAC-1BC9-4C74-8B11-E85973E5059E} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:46:32 Kristen DESKTOP-JO467M5 Install Save to Web and Mobile Feature Succeeded
2019/4/30:19:46:32 Kristen DESKTOP-JO467M5 Installing Autodesk Single Sign-On: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD LT® 2020" SETUP_PACKAGECODE={28B89EEF-3009-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={7F468CAC-1BC9-4C74-8B11-E85973E5059E} ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:46:38 Kristen DESKTOP-JO467M5 Install Autodesk Single Sign-On Succeeded
2019/4/30:19:46:38 Kristen DESKTOP-JO467M5 Installing Autodesk® AutoCAD LT® 2020: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\x64\en-us\acadlt\AcadLTLP\acadlt.mst;C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\x64\acadlt\acadlt-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:49:35 Kristen DESKTOP-JO467M5 Autodesk Desktop App return code: 0
2019/4/30:19:49:35 Kristen DESKTOP-JO467M5 Install Autodesk Desktop App Succeeded
2019/4/30:19:50:11 Kristen DESKTOP-JO467M5 Install Autodesk® AutoCAD LT® 2020 Failed Installation aborted, Result=1603
2019/4/30:19:50:12 Kristen DESKTOP-JO467M5 Installing Autodesk® AutoCAD LT® 2020: TRANSFORMS="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\x64\en-us\acadlt\AcadLTLP\acadlt.mst;C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\x64\acadlt\acadlt-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_LT_2020_SWL_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD LT 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2019/4/30:19:53:41 Kristen DESKTOP-JO467M5 Install Autodesk® AutoCAD LT® 2020 Failed Installation aborted, Result=1603
2019/4/30:19:53:41 Kristen DESKTOP-JO467M5 Component: ACADLT failed with code 16032019/4/30:19:53:42 Kristen DESKTOP-JO467M5 verifyCertificates The file "C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/30:19:53:42 Kristen DESKTOP-JO467M5 CertFindCertificateInStore C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\Setup\SolutionProvider.dll Succeeded
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 Download Error SOLUTION_PROVIDER_PACKAGE
https://emsfs.autodesk.com/utility/SolutionFramework/FY19/2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 Failed to Download solution Stub: 19
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 verifyCertificates The file "C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 CertFindCertificateInStore C:\Users\Kristen\AppData\Local\Temp\_AI3C07.tmp\Setup\SolutionProvider.dll Succeeded
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 AnalyzeInstallFailure() for log file: C:\Users\Kristen\AppData\Local\Temp\Autodesk AutoCAD LT 2020 Install.log
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 AnalyzeInstallFailure() GetErrorontext returned: Error Context CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (84:F0) [19:53:41:282]: Note: 1: 2265 2: 3: -2147287035
MSI (s) (84:F0) [19:53:41:282]: Machine policy value 'DisableRollback' is 0
MSI (s) (84:F0) [19:53:41:282]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 19:53:41: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Return value 3.
MSI (s) (84:F0) [19:53:41:282]: No System Restore sequence number for this installation.
MSI (s) (84:F0) [19:53:41:282]: Unlocking Server
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 AnalyzeInstallFailure() GetErrorContext returned: Error String fatal error
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 AnalyzeInstallFailure() QueryAknURL returned: AKN Article
https://knowledge.autodesk.com/search?p=ACDLT&search=fatal error&sort=score&page=1&v=2020
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 AnalyzeInstallFailure() error 28672 mapping not found in error.xml
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 Rollback: Autodesk Desktop App component is exe :Ignored Rollback.
2019/4/30:19:57:02 Kristen DESKTOP-JO467M5 Rollback: Autodesk Licensing component is exe :Ignored Rollback.
2019/4/30:19:57:05 Kristen DESKTOP-JO467M5 Rollback Autodesk Single Sign-On Succeeded
2019/4/30:19:57:06 Kristen DESKTOP-JO467M5 Rollback Save to Web and Mobile Feature Succeeded
2019/4/30:19:57:11 Kristen DESKTOP-JO467M5 Rollback Autodesk Material Library 2020 - Base Image Library Succeeded
2019/4/30:19:57:22 Kristen DESKTOP-JO467M5 Rollback Autodesk Material Library 2020 Succeeded
2019/4/30:19:57:22 Kristen DESKTOP-JO467M5 Rollback: DirectX Runtime component is exe :Ignored Rollback.
