Communauté
Abonnements, Installation et Licences - Français
Bienvenue sur les forums Abonnements, Installation et Licences d’Autodesk. Partagez vos connaissances, posez des questions, et explorez les sujets populaires.
annuler
Affichage des résultats de
Afficher  uniquement  | Rechercher plutôt
Vouliez-vous dire :
Problème d'activation de licence
1 RÉPONSE 1
Répondre
Message 1 sur 2
claudia.cotting
379 Visites, 1 Réponse
Bonjour,
Je ne peux activer ma licence car j'ai une case blanche. Merci de m'aider,
1 RÉPONSE 1
Message 2 sur 2
@claudia.cotting
I stole this wording/reply from my buddy @Darin.Green, so he takes all the credit for the steps..  Smiley clignant de l'œil
This should help get your application working. Assuming you have a valid serial number/contract.
Close the application
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
On your computer, navigate to: ​​C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F  [<Product Key> is the product key of the Autodesk Application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Start the application.
When you start the application, it will prompt you to choose one of the following:
Login - 30 day trial licenses
Serial Number - Standalone and Single-User activation
Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.  Students will always select serial #.
Mark Lancaster
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
Publier dans les forums
