Problema en la instalacion
Buenas noches disculpen, tengo una computadora toshiba core i7 6ta generacion con windows10 de 64bits
lo que pasa es que no puedo istalar el programa, siemre me da error, una vez ya se instalo pero al momento de ejecuatrlo no corria y de la nada mandaba a resetear la comoutadora y no funciona, no se que hacer
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, one they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
