Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Problem with volume of Autocad and Revit 2020
1 RESPUESTA 1
Responder
Mensaje 1 de 2
hanifbakhshi3
93 Vistas, 1 Respuesta
  • Hi,I downloaded Revit and AutoCAD version 2020 in rar and encrypted format from internet and when I put the pass word and want extract it doesn't work and the message says Next volume is required "you need to have the following volume to continue"Autodesk.Autocad.2020.*64_YasDL.com.part2.rar"  and also says "insert a disc with this volume and press OK to try again or press Cancel to break extraction" and the same message comes with extraction of other higher versions of Autocad and revit 2020-2025.
Etiquetas (2)
Etiquetas (1)
  • Volume
1 RESPUESTA 1
Mensaje 2 de 2
pendean
en respuesta a: hanifbakhshi3
@hanifbakhshi3 wrote:
  • Hi,I downloaded Revit and AutoCAD version 2020 in rar and encrypted format from internet and when I put the pass word and want extract it doesn't work ...
That is likely to be illegally sourced and licensed software: no one at Autodesk (or in these forums) can help you with that issue at all. Sorry.
Publicar en los foros
Administrator Productivity
