Buenas tardes me he descargado del asistente virtual el Advance Steel 2017 para estudiantes y al iniciar me sale esta imagen adjunta.
Ya tengo instalado el autocad 2017.
Que Problema se debe ya descargue ese archivo " odbcji32.ll " y aun asi no inicia el Advance.
Mucha gracias por la ayuda que me puedan brindar.
Solved by natasha.l. Go to Solution.
Google Translate
Good afternoon I downloaded the Advance Steel 2017 virtual assistant for students and from the beginning I get this attached image. I already have AutoCAD 2017 installed. What problem is already downloading that file "odbcji32.ll" and still does not start the Advance. Many thanks for the help you can give me.
Hello @JOCOAUTO,
This is mostly an English forum, I have translated your post for better feedback.
I have listed some steps to prepare your system for download and installation in case you run into a problem. That may be the issue and a different method of download as well.
Let us know how it goes.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
