POST error 404 (Not Found) for Java API
I am getting 404 error when I try to authenticate using AutoCAD IO, the URL I am trying is https://developer.api.autodesk.com/authentication/v2/authenticate.
I am trying the this link . Basically what we want an API for converting DWG/DXF files to PDF format in java.These files will be present on a particular server. Please help me here as I am stuck at this point.
Akhilesh
Below is the error message I am getting
Exception in thread "main" org.apache.http.conn.HttpHostConnectException: Connect to developer.api.autodesk.com:443 [developer.api.autodesk.com/54.76.8.168] failed: Connection timed out: connect
	at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:151)
	at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353)
	at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380)
	at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
	at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
	at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
	at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
	at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55)
	at auto.Main.getToken(Main.java:35)
	at auto.Main.main(Main.java:22)
Caused by: java.net.ConnectException: Connection timed out: connect
	at java.net.DualStackPlainSocketImpl.connect0(Native Method)
	at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:337)
	at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:134)
	... 12 more
dembkod
gupta.akhilesh
Hello. I am unsure if you are posting on the correct forum for your need. You appear to be running into a custom programming issue. You may be bettrer served referring to the Autodesk Developer Network. http://usa.autodesk.com/adsk/servlet/index?id=472012&siteID=123112
I am not exactly sure, but you may be better served there.
David Dembkoski
